Making any copy any of entity "copywithrefence" (RC) or "copy" (CP), then paste generated no copy but dot(?) line with length = 0. That dot can't be selected by mouse-direct-click, only can be selected by mouse's drag-"group select". Seems, draw is broken. How to repair? How to properly copy any entities? How to avoid convert copy of entities to such dot-"length=0"?
upd. "Paste scale" were 0.
How to solve trouble with copy?[SOLVED]
- LowerLoop1.dxf
- (252.52 KiB) Downloaded 219 times
- C3.png (12.8 KiB) Viewed 2584 times
Re: How to solve trouble with copy?
I can't reproduce the issue.
Where is this Zero lengths entity coming from? Do you copy/paste a line? What is the paste scale?
To get rid of all "Zero lengths entities" use below Menu / Modify / Detection / the "Detect Zero lengths Entities" tool.
https://www.youtube.com/watch?v=vkgtzZd15kI
Catch a video with bug(?).
Just select line; copy with reference; paste at other point; not a line, but dot length = 0.
Can't watch the video - it is privat!
SO sorry! Changed "draft" to "published", checked other browser.
https://www.youtube.com/watch?v=vkgtzZd15kI\
[SOLVED] Past scale = 0.
Re: How to solve trouble with copy?[SOLVED]
Not the first time I will be the advocate that scale = zero should be considered invalid.
Although mathematically correct, I see no practical meaning for this.
