[Solved] Linetypes
octavian
[Solved] Linetypes
Post by octavian » Tue Jun 14, 2022 11:38 pm
I am using HP Probook with windows 7 (it has a VGA port) and version 3.27.6. I cannot get dashed/dottd lines on my 23in monitor, or change line thickness. I can change the color from property editor. Also its weird that you can't change attributes under 'Modify'.
Re: Linetypes
Post by Husky » Tue Jun 14, 2022 11:52 pm
Is "Screen-Based Linetypes" activated below Menu / View?
octavian
Re: [Solved] Linetypes
Post by octavian » Thu Jun 16, 2022 1:12 am
Activated 'Screen-Based Linetypes' . Thanks.
