Hatch with pattern and background solid color
Kinzy
Post by Kinzy » Fri Jun 03, 2022 5:57 pm
In my plans I prefer to highlight the structure by using a darker fill color together with the pattern, but I can't find a way to do it in QCAD. Is it possible?
Screenshot 2022-06-03 195650.png (48.25 KiB) Viewed 1696 times
Windows 10
QCAD 3.27.6.0 (3.27.6)
Re: Hatch with pattern and background solid color
Post by CVH » Fri Jun 03, 2022 7:22 pm
In QCAD one can adjust the Alpha channel of solid fills.
See 'Specific Properties' in the property editor with the hatch entity in selection.
And a pattern and a fill means that you need to use two hatches.
Kinzy
Post by Kinzy » Fri Jun 03, 2022 9:35 pm
Thank you for your answer, but I was looking into having only one hatch to implement both pattern and solid background such as in ArchiCAD and Rhino 8's WIP. Maybe it could be a feature suggestion?
Post by CVH » Fri Jun 03, 2022 10:12 pm
Indeed :wink:
A hatch with foreground, background and that with an Alpha.
If DXF support it ...
