Windows 7, QCAD 3.27.5 or
MacOS Catalina 10.15.7, QCAD 3.27.5
I'm working on a drawing now to create a "map" of a school campus. Some of the building shapes are busy, so I'm drawing them off to the side. I want to select all the lines for the building when completed and make it a "xxxxxxxx" (the word I'm looking for).
That way I can select "xxxxxx" and bring it over to where I need it by the other buildings once completed.
[Solved]What is it called?
- ryancousins
- Premier Member
Re: What is it called?
A Block?
I've attached my starter drawing. There are more buildings to go but these are the first three. What I want to do is make Bldg 1005 one complete "thing" or "object" or as Ryan suggested a "block".
I want to move Bldg 1005 as one "thing" or "object" rather than all the lines one by one (which is how I created it). I want to take a corner of Bldg 1005 (the corner at 249'4", 149'0") and move the entire Bldg 1005 to closer to Bldg 1004. The point on Bldg 1004 that I want to get closer to is 216'0", 107'10". I'm trying to make the drawing full size, hence the big numbers in feet and inches an my X,Y co-ordinates.
I hope this makes sense, because I know I'm not using the correct CAD words to describe what I am trying to do.
- Campus Map.dxf
- (103.25 KiB) Downloaded 180 times
- ryancousins
- Premier Member
You can select multiple lines/objects and move them all together without having to create a block, but if you anticipate having to move a set of lines multiple times, it could certainly be helpful to turn them into a block. Otherwise, if you're just moving Bldg 1005 once, there might not be any advantage.
P.S. You are correct to draw the buildings in their real-life size. That is the standard practice in a CAD program.
Let us know if you would still like to create a block and need some guidance with that or anything else!
- Justmove.gif (1.5 MiB) Viewed 1957 times
