Quick Modify Tools Toolbar
Post by andrew » Sun May 08, 2022 1:35 pm
From a QCAD user:
How can I show the quick modify tools (move left, right, top, bottom, rotate CW, CCW) in a toolbar?
Re: Quick Modify Tools Toolbar
Post by andrew » Sun May 08, 2022 1:36 pm
View > Toolbars and Widgets > Toolbars > Quick Modify
petevick
Post by petevick » Sun May 08, 2022 6:18 pm
Andrew, the Quick Modify toolbar doesn't display any icons in 3.27.4
Pete Vickerstaff
petevick
Post by petevick » Sun May 08, 2022 7:06 pm
Pete Vickerstaff
Post by andrew » Sun May 08, 2022 7:52 pm
Did you try with 3.27.5?
petevick
Post by petevick » Sun May 08, 2022 8:08 pm
no, I haven't got around to downloading it, I'll give it a try tomorrow :wink:
Pete Vickerstaff
Post by Husky » Sun May 08, 2022 8:31 pm
After activating every single tool in "Application Preferences" / "Tool Settings" it launches like this ...
... which can be unfolded to:
Win10/64 QCAD 3.27.5
Post by andrew » Sun May 08, 2022 8:47 pm
Thanks Husky. Can you try to dock it and undock it again? It shouldn't actually launch undocked in the first place. Maybe it was undocked once in the past on your installation and it remembered a wrong size because of this?
Post by Husky » Sun May 08, 2022 9:37 pm
It was first launched undocked!
However it works now! As you said I docked it and it unfolded immediately by itself. Closed / opened QCAD = still unfolded. :D
Detached it / placed in a free area - still everything fine!
Rebooted QCAD - looks like ini is doing what it supposed to do ... :wink:
petevick
Post by petevick » Mon May 09, 2022 6:30 am
and that was the issue with 3.27.4, I hadn't activated each tool, although I can't remember having to do that on any other toolbar :?
Pete Vickerstaff
