[ Satisfied with Solution ] Convert Lots of Lines to Arcs
John Hyslop
Post by John Hyslop » Wed Apr 27, 2022 1:33 am
Hi All
Is there a way to reduce the entities in this file ? at the moment it has 1078 lines..
Is it possible to convert a bunch of lines into splines and then explode to arcs?
Any help will be appreciated..
Cheers
John Hyslop
PS I want to lasercut this..
Map.dxf
(358.66 KiB) Downloaded 238 times
Re: Convert Lots of Lines to Arcs
Post by Husky » Wed Apr 27, 2022 2:54 am
Sure - but you will loose details ...
No, not that I know of ... :oops:
What about a polyline with reduced segments?
BTW: Tasmania would be much less work .... :lol: :lol: :lol:
John Hyslop
Post by John Hyslop » Wed Apr 27, 2022 3:04 am
Hi Husky
I tried an AutoCAD Lisp file to convert polyline to spline but when I exploded it in Qcad I finished up with twice as many entities :lol:
Would you mind showing an example how to do this please :D
I don't mind loosing some.. :)
Cheers
John Hyslop
Post by Husky » Wed Apr 27, 2022 5:57 am
Select the whole contour,
launch "Polyline from Selection" (OC),
select the polyline,
launch "Simplify (OS),
"play" with the tolerance in the option bar to see what works best for you - I assume something between 0.1 - 0.5. The Tolerance bar has a Node indicator and a life preview is provided in the drawing too ...
John Hyslop
Post by John Hyslop » Wed Apr 27, 2022 6:11 am
Thanks Husky
That's Perfect Got Rid of All The Small Lines...
Cheers
John Hyslop
Re: [ Satisfied with Solution ] Convert Lots of Lines to Arcs
Post by Husky » Wed Apr 27, 2022 6:27 am
You're quite welcome!
Cheers. :wink:
