Hi All
I'm customizing Qcad ATM and would like to know how I can put an SVG file "icon" on some blank buttons without having access to the script itself?
I was thinking if I had a script that activated the command "BW" i could make my own button which might be easier..
There are a couple of icons missing from the "Make All White Layers Black" & "Make All Black Layers White" I'm only interested in the 1st one plus it might be easier as it has a hotkey BW... Could anyone help the 2 blank ones here are what I'm talking about..
And I would like to change at least the one on the left BW to this below..
Basic SVG here if someone wants to play with it..
Cheers
John Hyslop
Linux Mint 20.3 / QcadCAM Version 3.27.1
Put an SVG in a Blank Button
- Premier Member
Re: Put an SVG in a Blank Button
John,
icons are controlled within the init script ....
