Many Pages Multiple Viewports (Solved)
seasdes
Senior Member
Post by seasdes » Sat Mar 26, 2022 12:00 pm
I have a drawing that will have a number of pages Eg. cover sheet, site plan, floor plan, elevations and sections.
Each Viewport will have different layers toggled on.
Is this possible? I have read the manual.
Presently I have the floor plan overlaid on the site plan. Or should I have all layers toggled on and position each of the drawing views so that they do not overlay others (in this case the floor plan and site plan).
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Re: Many Pages Multiple Viewports
Post by Husky » Sat Mar 26, 2022 7:18 pm
What's about "Layer States"? Would that work in your case?
seasdes
Senior Member
Post by seasdes » Sat Mar 26, 2022 10:54 pm
Can I have different Layer States active on the one page?
seasdes
QCAD Pro V3.27.8
User since 2021
W10
ryancousins
Post by ryancousins » Sat Mar 26, 2022 11:07 pm
You can only have one layer state active at a time and it is across all viewports.
seasdes
Senior Member
Post by seasdes » Sat Mar 26, 2022 11:12 pm
Thanks Husky & Ryan
I wonder what other QCAD users do?
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Post by Husky » Sun Mar 27, 2022 12:41 am
With the information I have so far I would say forget the plan to print multiple pages at the same time. Do single prints - that are only 5, correct?
How:
Create a layout block for each plan, create a layer state for each layout block. If you name a layout block "Floor plan" create a corresponding Layer State named "Floor Plan". Create regarding to the plan the viewports and annotations.
Printing:
Double click on Layout "Floor plan" to open it, launch the corresponding Layer State "Floor plan", print the plan ...
Next - double click on Layout "Site plan" to open it, launch the corresponding Layer State "Site plan", print the plan ... I guess you get the idea. :wink:
