Property editor covers view
Marti
Post by Marti » Fri Mar 25, 2022 6:32 pm
Beginner question: my property editor covers the entire view! I try to move it to the right side where other lists are, but it always pops back to cover everything!
MacBook (Retina, 12-inch, Early 2016)
MacOs Monterey 12.2.1
QCAD Version 3.25.2.11
Re: Property editor covers view
Post by andrew » Fri Mar 25, 2022 6:33 pm
Might be easier to reset the QCAD configuration:
Marti
Post by Marti » Fri Mar 25, 2022 6:48 pm
That of course worked! Thanks!
(I should write down my preferences settings ...)
Post by Husky » Fri Mar 25, 2022 7:56 pm
Tip: Every time you change preferences in QCAD make a backup of the QCAD3.ini file. All preferences are saved in this file. If then something goes wrong like you have to reset QCAD etc. you can use this backup file to restore all previos made settings ... :wink:
Marti
Post by Marti » Mon Mar 28, 2022 8:59 am
Good advice, thanks!
