Hello, friends!
On my mechanical drawings, I usually find the necessity of using those different types of dimensioning for diametric/radius dimensions.
I would like to know if anyone else uses these kind of dimensioning and finds that it would be a great feature for a "feature request".
For the great qcad developers team, Is this practical/doable?
Thanks!!
More Radial/Diametric Dimension Types?
- Active Member
- 20220322_154039.jpg (2.51 MiB) Viewed 2697 times
Re: More Radial/Diametric Dimension Types?
However - the radial dimension with a break in the extension line is something what I really miss in QCAD. I would support a feature request.
Yes, I use them too. But ... a variant of the left example already exist in QCAD.zilmosantos wrote: ↑Tue Mar 22, 2022 7:52 pmI would like to know if anyone else uses these kind of dimensioning and finds that it would be a great feature for a "feature request".
- petevick
- Premier Member
I know this is a work around, but for the extension line break you could explode the dimension and use my Polyline break symbol (Misc>Draw) on the extension line, not ideal I know.
Pete Vickerstaff
- Active Member
Hi, Husky! Yes, this variant is interesting, but, at least in my opinion, having the option to make the dimension text and the extension line horizontal seems more elegant =) for mechanical drawings.
Great to know! Thanks!
- Active Member
