Reverse a lines Start and End points
himpelr
Post by himpelr » Sun Mar 20, 2022 11:27 pm
My suggestion is to easily reverse the start and end points of a line. There is an option when creating a line that gives the option to choose "Start", "Middle" or "End". Later on , for example, I sometimes need to change a lines' start and end points to be reversed. These locatons are shown "Property Editor" as "Start Point" with X and Y locations and "End Point with X and Y locations. All I need is as a command that will change the "Start Point" X and Y locations to the "End Point" X and Y locations and the "End Point" X and Y locations to the "Start Point" X and Y locations. This should leave the line in the same place on the drawing. The command name could be "FlipXY" for any type of straight line I would think. It would sure be handy!
Currently I can rotate a line by selecting the "Middle" and rotating 180 degrees. If there is already a one-click command to do this operation, I couldn't find it in the Reference Manual.
I am using QCAD 3.26 on a Desktop machine running Linuxmint 20.3, 2 -2.6 GHz processors and 8 GB memory with a 43" diagional monitor. I also have a little Apple laptop as a backup machine that runs just about everything that runs on the Linux box including QCAD 3.26. I think it's great that you provide the various version of QCAD with your distributions. I'm looking forward to version 3.
Richard Himpelmann
Ringwood, IL USA
email: [email protected]
Re: Reverse a lines Start and End points
Post by Husky » Mon Mar 21, 2022 12:19 am
Yep, there is already a command ...
Select the entity and launch below Menu / Modify the "Reverse" (RV) tool. :wink:
TSG
Post by TSG » Mon Mar 21, 2022 8:37 am
Actually, why isn't the icon for the "Reverse" command shown in the tool matrix?
Thomas
petevick
Post by petevick » Mon Mar 21, 2022 12:56 pm
Thomas
It is on my system. Go to Edit> Application Preferences, in the General section select Tool Settings. In the Filter field type Reverse, select Reverse from the results and in the Visibility tab check Tool matrix.
Pete Vickerstaff
petevick
Post by petevick » Mon Mar 21, 2022 12:59 pm
actually you are correct, even with it checked in Tool settings it doesn't appear in the Tool Matrix :?: :?: :?:
Pete Vickerstaff
Post by CVH » Mon Mar 21, 2022 1:56 pm
3 hours ago Andrew added it to the Toolmatrix.
See ReverseInit.js: https://github.com/qcad/qcad/tree/maste ... fy/Reverse
Still excluded for the ModifyToolsPanel.
That is for a new update/snapshot.
petevick
Post by petevick » Mon Mar 21, 2022 6:17 pm
Thanks for that CVH 8)
Pete Vickerstaff
