How do I make QCAD work faster?
David Kolínský
Post by David Kolínský » Fri Mar 18, 2022 7:00 pm
Hi, when I open a medium size dwg file in AutoCAD it´s running very smoothly. But when I open the same file in QCAD it´s just lagging and It´s almost impossible to work in QCAD.
Is there anything I can do to make QCAD run faster?
Thank you for any help :D
Re: How do I make QCAD work faster?
Post by Husky » Fri Mar 18, 2022 7:40 pm
To help you efficiently we need to see the particular drawing. Please attach the drawing to your post. Thanks.
David Kolínský
Post by David Kolínský » Fri Mar 18, 2022 7:59 pm
Here is the drawing. When I zoom a lot it´s not lagging anymore but when I do not zoom it´s a lagging.
projekt KO Trtílková + RD Blažkovi_Ostrava-Svinov.dwg
(1.12 MiB) Downloaded 231 times
Post by Husky » Fri Mar 18, 2022 8:33 pm
Thanks for the drawing!
It is not really slowing down on my system but fact is that an intense use of hatches will slow down the rendering process. It looks like most of your 565 hatches are on layer "srafa". If you turn this layer invisible will you still experience lagging?
Edit: Additional I recommend to remove also those 177 duplicates and the 'lost" entities around the actual drawing which will reduce the file size by approx. 38.5 % ... that will help to speed things up. :wink:
Post by CVH » Sun Mar 20, 2022 4:31 pm
Also, have a closer look at 'GRAVEL1' hatched areas.
They look crippled and the reason is that the Hatch origin is far away from the area itself.
We know QCAD renders Hatches nicer and faster when the origin is set nearer.
Isolating Hatch entities on a dedicated layer is advised.
Locking that layer may also reduce lagging as it avoids highlighting and re-rendering.
John Hyslop issued an optimized replacement for the old and badly coded pattern 'GRAVEL' called 'GRAVEL-01'.
Based on gathered knowledge of a joint venture. It's all about angles :wink: .
