[Solved] Batt insulation hatch
Re: [Solved] Batt insulation hatch
Post by CVH » Sat May 07, 2022 3:37 am
MightyHumbleBumble,
Hatching is based on an hatch origin.
So you could play with that origin to fit the pattern.
See Property Editor with the hatch in question selected.
