Can I create a PDF File while saving
Robert Fetherlin
Post by Robert Fetherlin » Wed Mar 16, 2022 1:33 pm
I only use QCAD about once or twice a year for personal use. I do not have a large format printer. How do I save my drawing to a PDF File so I can take a thumb drive down to the office store for printing?
I can cut and paste 9 pages, but that doesn't look very good. There appears to be a million formats to save your work within, but none of them appear to be a PDF File. Maybe the office store can print a file from one of those file formats?
I am using a Windows 11 laptop.
I am using the latest version of QCAD, I only purchased it about 6 months ago.
Thank you for your help
Jims Deck modification.dxf
(1.57 MiB) Downloaded 190 times
Re: Can I create a PDF File while saving
Post by andrew » Wed Mar 16, 2022 2:43 pm
Post by Husky » Wed Mar 16, 2022 7:16 pm
What is your goal? Print the whole drawing on one ANSI A page?
Robert Fetherlin
Post by Robert Fetherlin » Tue Mar 22, 2022 3:24 am
I'm not sure what an ANSI page is. My drawing fits on a 2' x 3' page. It takes 9 pieces of paper to print on my home computer. I would like to be able to take it to a print shop and have it all printed on one sheet of paper.
Do most print shops have QCAD on their computers or can I convert my existing drawing into a PDF file so that someone else can print it?
Robert Fetherlin
Post by Robert Fetherlin » Tue Mar 22, 2022 3:30 am
I think I may have found it under Print/PDF export. Thank you. I will go down to the print shop and try it out. I was looking under File/print. Obviously it wasn't there. Thank you very much
Post by Husky » Tue Mar 22, 2022 4:13 am
Most likely what you see in QCAD is an Array of 9 ANSI A pages.
I don't know which software is used by that particular print shop but I'm sure that they can process ALL formats created in QCAD.
Great! If you run in any trouble we are here to help ... :wink:
