My drawing, including the linetype scales, looks good in the main widow, but when I go to Print Preview (and when I print) all lines appear as solid. See attached screenshots.
I am using Windows 10, QCAD Version 3.26.4. What setting am I missing?
Linetype scale when printing (Solved)
- Linetype scale correct
- Main Drawing.jpeg (182.15 KiB) Viewed 1603 times
- Linetype scale missing
- Print Preview.jpeg (157.27 KiB) Viewed 1603 times
Re: Linetype scale when printing
How does the print looks with a Line scale of 1?
Re: Linetype scale when printing (Solved)
Yes. That must be set to "1" in the Print Preview as well. Thanks!
