Best Pressure Washer: The Top 3 Picks You Need
Re: Can QCAD Geolocate Coordinates?
Post by andrew » Wed Mar 09, 2022 4:55 pm
Typically one would create a drawing in a known CRS. QCAD can also transform between different CRS. However, moving 0/0 would be exactly the same as creating the drawing in the desired position in the first place or moving it to the desired position afterwards.
