Let's say I have a line and I want to draw a second line perpendicular to the first line. Where the end of the second line touches some point on the first line.
Is there a single command way of doing this?
I'm using Windows 10 Pro. and QCAD version 3.23.0.0.(3.23.0)
Draw Line Perpendicular to another line?
Re: Draw Line Perpendicular to another line?
Will the Orthogonal Tool do the trick for you ...?
https://www.qcad.org/doc/qcad/latest/re ... al_en.html
Yes, the orthogonal tool works! Thanks! I had tried using the orthogonal tool earlier - but confused the intersection tool with the orthogonal tool - the icons look similar.
