How to close corners of differtent splines in script
Kv12
Post by Kv12 » Sat Jan 22, 2022 11:17 pm
I have a problem closing the corners of a "square" of four splines in a script for Qcad. The coordinates of the hitpoints for the splines a the results of a measuring tool; they will become variable in a later stadium.
//coordinaten voor de raakpunten van de splines
//links
var l=[];
l.push([100,100]);
l.push([105,500]);
l.push([102,1000]);
//boven
var b=[];
b.push([120,1050]);
b.push([500,1060]);
b.push([800,1040]);
//rechts
var r=[];
r.push([900,900]);
r.push([890,600]);
r.push([920,110]);
//onder
var o=[];
o.push([800,75]);
o.push([400,90]);
o.push([130,80]);
// teken fitpoint splines met bovenstaande coordinaten
SplineObjL = addSpline(l, false);    // NOTclosed periodic
SplineObjB = addSpline(b, false);    // NOTclosed periodic
SplineObjR = addSpline(r, false);    // NOTclosed periodic
SplineObjO = addSpline(o, false);    // NOTclosed periodic
Using Qcad professional 3.25.2.0 and Windows 10
Does anybody have an idea?
closecorners.dxf
result
(104.18 KiB) Downloaded 187 times
Re: How to close corners of differtent splines in script
Post by CVH » Sun Jan 23, 2022 8:07 am
not really ... :?
First: addSpline(...);
Adds a fitpoint spline entity by using the simple API.
You don't have to store the result in a variable called 'SplineObj...'
Here an undeclared one, remark that we use variable names starting with a lowercase.
Unless you need that as a reference of the created drawing entity for another purpose.
The reference would only be valid without using a transaction to group additions/modifications to one action.
If you want to do further modifications, you can do that on a lower mathematically level before entities are added.
Second:
The 4 splines are not really 'connected' so the corners are indeed open.
The left one ends at (102,1000).
The top one starts at (120,1050).
That ends at (800,1040).
The one on the right starts at (900,900).
And so on.
I know that splines with control points can be tweaked to have hard corners.
With 3 successive control points at the same spot.
But that won't serve your needs as it aren't fitpoints aka 'raakpunten'.
It is not good practice either.
QCAD can not trim your splines pairwise. :shock:
There is no natural defined way in how a spline should continue beyond its endpoint. e_geek
The attached dxf includes polylines. It seems L-T-R are trimmed pairwise.
The ending segments of polylines from exploding splines are approximations of the local curvature.
Those ending arcs depends primarily on your explosion (XP) preferences.
Both ending arc segments can indeed be trimmed pairwise.
Still, that isn't a natural continuation of the original splines themselves. :wink:
QCAD can trim fitpoint splines that actually cross another entity. 8)
Remind that when trimming fitpoints splines, control point splines are returned.
That is to keep the tangent of the spline in the intersection point. e_geek
Thinking outside the box:
Your splines are each defined by 3 points.
Maybe a 3-point arc would serve your needs. :?
The differences are very minute. :wink:
Kv12
Post by Kv12 » Sun Jan 23, 2022 9:29 pm
Thx CVH for your reaction.
In this example the splines indeed are defined by 3 points, but they will be defined by 5 or more points later on, so a 3 point arc won't work.
The attached DXF does indeed include polylines. This was not the result of te script; I manually modified them afterwards and forgot to undo this action before saving. I discovered that when I changed them into polylines, I was able to close the corners by using "Trim Both" (manually). In a way this is a solution for my problem, but I would like to accomplish this in a script, but cannot find out how..
Hope you can help me further with this information?
Kv12
Post by CVH » Mon Jan 24, 2022 6:36 am
Kv12,
forgot to undo this action before saving ...
I understand, and by undoing you undo the trimming and the explosion and return to open corners ... :(
The easiest route:
- defining splines from intersection point to intersection point.
  • Using the simple API as in your example.
The only perfect solution ... e_geek
The simple_modify API also provides a method for trimming two entities:
https://qcad.org/doc/qcad/3.0/developer ... 37b8b53b93
Again, that will throw an exception with splines and open corners.
Getting polylines from splines is explained lower (approximateWithArcs).
Casting the polylines keeping a reference and then trimming them pairwise ...
... You need to provide 'clickpoints' as if your are doing it manually. :(
I would use the lower level mathematically approach. :wink:
The spline route:
- having points to define splines that actually cross.
  • Creating math level shapes RSplines.
    Get the intersection point pairwise.
    Trimming each spline shape twice at the returned intersections.
    Casting the resulting control point spline shapes as drawing entities.
This would be nearly perfect ... :P
var splineXX = new RSpline([collection of fitpoints], degree); For each spline shape.
https://qcad.org/doc/qcad/3.0/developer ... 725f28eff7
var intersectionPointsA = RShape.getIntersectionPointsSS(splineXX, splineYY); For each pair of splines (Always a list).
https://qcad.org/doc/qcad/3.0/developer ... 6aa5519660
splineXX.trimEndPoint(intersectionPointA); For each endpoint.
https://qcad.org/doc/qcad/3.0/developer ... c5afa23c4c
Remind: requires PRO, check if intersections points are returned, check if it is just one and that it is a valid RVector.
if (intersectionPointsA.length === 1 && isValidVector(intersectionPointsA[0])) {
    // Trimming the shapes in question
else {
    // Error & skip or terminate
Casting resulting splines shapes to the document in one single operation.
var di = this.getDocumentInterface(); // Valid if there is an active document
var doc = di. getDocument(); // A reference to the document
var op = new RAddObjectsOperation();
var splineData, splineEntity; // Declaring common variables
// For each final spline shape:
splineData = new RSplineData(splineXX);
splineEntity = new RSplineEntity(doc, splineData);
// Adding the new entity to the operation
op.addObject(splineEntity, true, false); // useCurrentAttributes, NOTforceNew
// Finally applying all additions:
di.applyOperation(op);
The polyline route:
This may look OK but you don't really extend the splines.
You only extend the last arc segment at each polyline ending. :!:
var polylineXX = splineXX.approximateWithArcs(tolerance); Requires PRO.
https://qcad.org/doc/qcad/3.0/developer ... d09aa2e319
One can opt for a fixed tolerance or:
    // Retrieve approximation tolerances of the Explode method (XP), if any, or use defaults:
    var sTol = RSettings.getDoubleValue("Explode/SplineTolerance", 0.01);    // Default =0.01 deviation
var intersectionPointsA = RShape.getIntersectionPoints(polylineXX, polylineYY, false, false, false); Always a list.
https://qcad.org/doc/qcad/3.0/developer ... 9c209339e1
polylineXX.trimStartPoint(intersectionPointA, RVector.invalid, true);
https://qcad.org/doc/qcad/3.0/developer ... 357eb67c3f
polylineXX.trimEndPoint(intersectionPointB, RVector.invalid, true);
https://qcad.org/doc/qcad/3.0/developer ... 5957b8569d
Seems easy enough but remind that arcs can intersect once, twice or not at all.
I asume that the shortest solution is returned.
One can tweak that with using a specific so called 'clickpoint' other than RVector.invalid.
Casting the resulting polyline shapes to the document is analog to the above with splines.
Replace 'spline' with 'polyline' textual, mind the upper/lower case.
One could even merge the polylines, appending individual shapes from successive polylines.
Personally I am not fond on how QCAD prepend/append arc shapes to polylines. :(
All QCAD open source scripts:
https://github.com/qcad/qcad
All QCAD resources:
- Classes: https://qcad.org/doc/qcad/3.0/developer/annotated.html
- Modules: https://qcad.org/doc/qcad/3.0/developer/modules.html
Post by CVH » Mon Jan 24, 2022 9:09 am
Kv12,
Seems less straightforward to implement as how it is explained in the resourses ....
Had to tweak the spline shape creation a bit.
At first it returned no intersections at all.
You can run this script from its saved location with Misc menu .. Run Script (XC) ... :D
With at least an empty document, limited to 'links' and 'boven' as example.
A *.js script is plain text. :wink:
TrimmingSplinesEX.js
(2.67 KiB) Downloaded 195 times
You can reach me in Dutch by PM, I am from Belgium, Antwerp. :wink:
