layers from csv file
Clifferator
Post by Clifferator » Mon Nov 29, 2021 9:30 am
Hi all
I'm using QCad for land surveying projects, and the new 'import csv' feature has been a fantastic addition, thank you.
When I import points with codes I would like to have all codes in separate layers - codes might be for 'fence', 'building', 'edge of concrete' etc. I can sort data in my csv file then save each group so there's a separate file for each code type, then import them into QCad as a layer for each... it works ok but it's a clunky method, is there a better way I could do this?
Re: layers from csv file
Post by andrew » Mon Nov 29, 2021 4:14 pm
No, I don't think there's a better way.
Post by CVH » Tue Nov 30, 2021 9:35 am
could you upload an example on how your data is organized?
You can also reach me by Private Message. :wink:
