text in script shell
BJohnny
Post by BJohnny » Sat Nov 27, 2021 4:39 pm
QCAD (Windows 10)
Version: 3.26.4.0 (3.26.4)
need support on syntax adding text in script shell ...
addSimpleText("XYZ",x,y,0,"standard",RS.VAlignTop,RS.HAlignLeft, "not bold","not italic");
(want text centered, not bold, not italic)
appreciate hint on a proper command example
Re: text in script shell
Post by CVH » Sat Nov 27, 2021 5:24 pm
want text centered
RS.VAlignMiddle, RS.HAlignCenter,
See:
https://qcad.org/doc/qcad/3.0/developer ... 165423f1cb
https://qcad.org/doc/qcad/3.0/developer ... a99af76782
See:
https://qcad.org/doc/qcad/3.0/developer ... 38e26ad26d
BJohnny
Post by BJohnny » Sun Nov 28, 2021 10:25 am
thanks a lot CVH
working just fine now
Regards
