Hello!
I am not a CAD user nor am I an architect. I'm a complete newbie. However, I have very comprehensive CAD files for my line of work and I know the file I have has multiple "tabs" or "pages" within the file. If the .dwg is opened in AutoCAD you can see these tabs at the bottom of the viewer and switch between each tab/page.
When I open the .dwg in QCAD I cannot find any similar function for toggling or opening the other tabs within the file. Is this not supported? I have searched google and this forum for a similar question but haven't seen anything. I also went through the full feature set within QCAD and didn't see anything relevant. Please help!
I am using the trial MacOS version of QCAD 3.26.
Edit: Is this feature available in the paid version only?
Thanks in advance!
Help! Toggle between pages / tabs?
Re: Help! Toggle between pages / tabs?
To launch the Block list check Menu / View / Block List.
If that doesn't solves the problem please attache the drawing or an example drawing which shows the same issue. Thanks.
Please check the "Block List" for those "Pages". They could be "Paper_Spaces".
