Is there a way to get the area of a hatch?
zilmosantos
Post by zilmosantos » Mon Oct 18, 2021 2:00 pm
Friends, on my projects I always need to insert the weight of the parts in the parts list.
I work with QCAD at my part time job at my home.
If I have a piece with a lot of holes or a complex geometry, the way I'm used to get the area in my main job software (AutoCAD) is make a hatch and the area of it and in an excel sheet I insert the area, the depth and get the weight of the part.
Is there a way to get the area of a complex geometry in qcad without need to take the area of every little part and make calculations by hand?
The images show an example of what I'm saying.
The area is shown in the properties tab
Complex geometry with hatch to get the area
ryancousins
Re: Is there a way to get the area of a hatch?
Post by ryancousins » Mon Oct 18, 2021 2:15 pm
I do not believe the area of a hatch is currently a value that is automatically generated or that can easily be generated except with the method you describe where you would subtract the value of each cutout manually. Someone with a little scripting ability could probably automate that. I wish that were something I knew how to do!
Post by CVH » Mon Oct 18, 2021 3:09 pm
Post by CVH » Fri Oct 29, 2021 12:05 pm
Please refer to:
viewtopic.php?t=8846
zilmosantos
Post by zilmosantos » Fri Oct 29, 2021 1:59 pm
Please refer to:
Thank you so much and congratulations for your great efforts to help the community, CHV!! I'll test it ASAP.
