Hi
Just had to upgrade my Pc and have re installed Qcad, my question is on a Windows 10 machine can you put your own library components in another directory with your work files or do they have to be in the default location under the Qcad installation directory. The reason I ask is that my C drive is a smaller M.2 SSD which holds the Os and programs whilst I have a large HDD drive for all the working type files.
thanks Roy
(Solved) Library location
Re: Library location
Please refer to our tutorial at:
https://www.qcad.org/en/tutorial-workin ... rt-library
Thanks for that, just what I could not find
