Check Z value (in X,Y,Z - elevation height)
BellaDaddy
Post by BellaDaddy » Sun Sep 05, 2021 7:43 am
So Can I use(check) Z value(in X,Y,Z - elevation height) ?
Whether Qcad 2D , even less , I wish to handle checking(selecting) Z value on entities(blocks) like that user select Z to 0 or Z to original data(remained) if user wants ?
please consider this.
thanks. ^^
(excuse me on not good English sentences , I am Korean)
ex) in autocad
-vp 0,1,0
-ch p > e > 0
plan
Version:
3.26.4.0 (3.26.4)
Internet:
QCAD.org
Build Date:
Jun 4 2021
Revision:
0bb4334
Qt Version:
5.8.0
Architecture:
x86_64 ubuntu 20LTS
Compiler:
gcc 4.8.1
Re: Check Z value (in X,Y,Z - elevation height)
Post by andrew » Sun Sep 05, 2021 10:12 am
This preference might be what you are looking for:
Edit > Application Preferences > Widgets > Property Editor > Display Z coordinates
You can then display and change Z coordinates in the property editor:
Screenshot 2021-09-05 at 11.11.43.png (68.95 KiB) Viewed 3468 times
BellaDaddy
Post by BellaDaddy » Tue Sep 07, 2021 4:08 am
very very very much thank you for teaching this.
WOW, this is very useful and necessary to edit maps (with Cartographic works using QGIS program)
I again love QCAD.
thanks alot , Andrew.
BellaDaddy
Post by BellaDaddy » Tue Sep 07, 2021 4:33 am
Is it possible to set the z-value to 0 for all layers except some layers(Contour line,elevation point) at once?
Post by CVH » Tue Sep 07, 2021 7:38 am
Hi, please one question per topic. See forum rules at the top.
No, one can't set coordinate values that are inherited by layer.
One can select all entities on a layer and set the Z value of the selection by the Property Editor.
Without selection right-click on the layer in the Layer List and choose Select Layer Entities (Y+).
BellaDaddy
Post by BellaDaddy » Wed Sep 08, 2021 3:04 am
I'm really sorry , apologize that missing rule.
and thanks a lot the notice
