text/label angle
- bambuko
- Senior Member
text/label angle
Is it possible to customise label angle for dimensions (other than horizontal ones) so that the label is always horizontal? regardless of dim orientation
QCad Pro
Linux MX-21.3 "Wildflower"
Re: text/label angle
Only ISO dimensions are currently supported by QCAD. Forced horizontal labels are planned for the next (snapshot) release.
- bambuko
- Senior Member
Thank you!
When can I expect snapshot release?
BTW I am already waiting for one that would address issue of path difference between linux and windows for inserted images,
see:
https://qcad.org/rsforum/viewtopic.php?t=8570
see:
QCad Pro
We will release a new snapshot once these things are fully implemented and all unit tests pass.
- bambuko
- Senior Member
Thank you!
I assume it will be announced here on the forum when it is ready?
QCad Pro
Yes!
