Arch D Size Project Master Sheet with Header
- Newbie Member
New to QCAD and my first real issue, is how to create a JOB MASTER SHEET with project header and space for Job No. and Revisions Column etc. that I simply import my floor plans, cross sections, long sections and elevations into, at appropriate scale (anywhere from 1"= 8'-0" to 1" = 2'-0"). I want to do a test sheet with various line weights, dimensions and text sizes as a trial print in order to know what will be the best, when I do have prints made for the job. Also, I am assuming I will need to export the sheets as PDFs in order to have files I can take to a print service, since I do not have a printer that will print 36X24 size sheets. Than you
Re: Arch D Size Project Master Sheet with Header
Have you noticed this page with example drawing sheet templates? Maybe it can make your life easier ...
viewtopic.php?f=51&t=2498
- Newbie Member
Thanks - That will certainly help me.
