How can I add a tolerance to a single dimension?
Add tolerance for a dimension
From a QCAD user:
Re: Add tolerance for a dimension
Changing upper / lower limits
1. Select the dimension(s) to add a tolerance to.
2. In the property editor (View > Property Editor), enter the lower and upper value to display as shown here: For example:
Adding text to a dimension label
Alternatively, you can add a tolerance (or any text) by changing the property Label. For example change the property Label to:
<>±0.1
This will display the measured value (<>) and ±0.1 as the dimension label:
<>±0.1
