Add tolerance for a dimension
Post by andrew » Tue Aug 10, 2021 10:53 am
From a QCAD user:
How can I add a tolerance to a single dimension?
Re: Add tolerance for a dimension
Post by andrew » Tue Aug 10, 2021 10:58 am
Changing upper / lower limits
1. Select the dimension(s) to add a tolerance to.
2. In the property editor (View > Property Editor), enter the lower and upper value to display as shown here:
Screenshot 2021-08-10 at 11.54.51.png (29.06 KiB) Viewed 2067 times
For example:
Screenshot 2021-08-10 at 11.55.04.png (21.11 KiB) Viewed 2067 times
Adding text to a dimension label
Alternatively, you can add a tolerance (or any text) by changing the property Label. For example change the property Label to:
<>±0.1
This will display the measured value (<>) and ±0.1 as the dimension label:
Screenshot 2021-08-10 at 11.57.40.png (20.35 KiB) Viewed 2067 times
