as title
win 7
qcad pro 3.26.4
how do i turn off solid and hatch?
Re: how do i turn off solid and hatch?
In CAD it is common practice to control the visibility of entities with layer. To be able to toggle the visibility of e.g. hatches put all hatches on a layer and switch from visible to invisible as you need it in your workflow.
You can find a bit more info about layer in this tutorial:
https://qcad.org/en/tutorial-working-with-layers
- Junior Member
Thank you for the layers tip with Hatch ( I didn't realise that). A great timesaver!
