I am using the PDF Export to create pdf files to send to the printer. I noticed that the dpi files are being exported at 72dpi. Is there anyway that I can increase dpi to 300? And if so, will this change the actual dimensions of the print?
[solved] PDF Export (XD) - How to control dpi
Mac: Big Sur version 11.4
QCAD Pro
QCAD Pro
Re: PDF Export (XD) - How to control dpi
PDF is a vector format and as such can be scaled up without loss. If you have bitmaps in your PDF, their resolution depends on the image file and its scale.
Perhaps this helps to better understand PDF and resolutions:
https://bytescout.com/blog/dpi-resoluti ... ument.html
Great article, thanks for posting the url. It has helped me narrow down my problem.
How do I mark that this issue has been solved?
QCAD Pro
QCAD Pro
