Scale Selection to known Dimension
Helipil0t
Post by Helipil0t » Wed Aug 04, 2021 6:27 pm
QCAD Version: 3.26.4
OS: Linux (Ubuntu 20.04)
So in Autocad I was about to highlight a selection that I would like to scale, then select two points between a known measurement and indicate the dimension. Then Autocad would scale my selection appropriately. No math required. Is this possible in QCAD? All I see is the Scale command where I need to input the ratio manually. Would be nice to say, this line in this selection needs to be 4 feet. Then let QCAD work out the ratio automatically.
Am I missing an option somewhere?
Thanks!
Re: Scale Selection to known Dimension
Post by andrew » Wed Aug 04, 2021 6:55 pm
Modify > Align Reference Points (with the scaling option enabled) should do the trick:
https://qcad.org/doc/qcad/latest/refere ... encePoints
