Rectangle tool to create a Polyline Rectangle
Circle
Post by Circle » Wed Jul 28, 2021 2:43 pm
I am sure there is a setting to change the outcome of the Rectangle tool to create a Polyline Rectangle vs 4 individual segments. I notice that the circle tool maintains the parameters of a circle. This allows you to pick the circle from its center.
If I currently draw a rectangle tool, I cannot then click on one segment to select the entire rectangle, what happens is that only the rectangle I click on is selected.
How do I maintain the parameters of the rectangle?
Thanks.
Mac: Big Sur version 11.4
QCAD Pro
Re: Rectangle tool to create a Polyline Rectangle
Post by andrew » Wed Jul 28, 2021 3:03 pm
Please always check the options toolbar at the top for available tool options:
Screenshot 2021-07-28 at 16.02.36.png (14.07 KiB) Viewed 3828 times
Post by CVH » Wed Jul 28, 2021 3:04 pm
See Options toolbar (Toolbar is commonly used by most methods)
The tools parameters are persistent between calls. (Also for most tools)
What you mean by the rest is a mystery :?
If I currently draw a rectangle tool, I cannot then click on one segment to select the entire rectangle, what happens is that only the rectangle I click on is selected.How do I maintain the parameters of the rectangle?
Circle
Post by Circle » Wed Jul 28, 2021 3:29 pm
That is so cool. Thanks.
I notice that the rectangle polyline object is not snapable to the center of the rectangle. Is this correct?
QCAD Pro
Post by andrew » Wed Jul 28, 2021 3:51 pm
Correct. There's no "rectangle" shape in CAD (or DXF/DWG). The rectangle tool is a convenience tool that creates four lines or a polyline in the shape of a rectangle.
Note also the Snap > Middle Manual snap tool that can be used to snap the center of a rectangle or similar shape:
https://qcad.org/doc/qcad/latest/refere ... ddleManual
Circle
Post by Circle » Wed Jul 28, 2021 4:02 pm
Thanks Andrew
QCAD Pro
