Dimensions - Fixed Length Extension Lines
seasdes
Senior Member
Post by seasdes » Fri Jul 16, 2021 4:23 am
Is there a way to set the length of fixed extension lines before I insert a dimension?
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Re: Dimensions - Fixed Length Extension Lines
Post by Husky » Fri Jul 16, 2021 7:52 pm
No, not that I know of. But you can change the fixed line for all dimension afterward in one step within the Property Editor. Using for selection the layer functionality or the selection filter ... :wink:
