[solved] Cannot select individual drawing elements
RogerRamjet
Post by RogerRamjet » Fri Jul 09, 2021 7:21 pm
I created a drawing last night and everything worked as expected. Saved it, shut-down the computer.
Now when I open the drawing this morning...
1. When I try to select an individual element like a line, or text, the entire drawing "grays-out" instead of only the target element.
2. Also, when I double-click on some elements, I'm suddenly zoomed-in on that element in another area on the drawing. It appears that I don't know what double-clicking does.
I'm guessing that I'm stuck on some mode that I'm unaware of.
Not sure I'm explaining my issues very well since I don't yet know the QCAD "vocabulary".
TIA,
QCAD Pro, v 3.26.4
Win10 Pro
ryancousins
Re: Cannot select individual drawing elements
Post by ryancousins » Fri Jul 09, 2021 7:49 pm
Without having a copy of your file to mess with, it sounds like you created a block from some or all of the parts of your drawing. If you want to make everything it's own separate entity again, select everything (clicking once on any of the entities in question will automatically select all of the entities that may have been grouped together in your block) and then choose "explode" in the block menu bar, or use the keyboard shortcut xp
It also sounds like you might have "edit block reference in place" enabled, which you may or may not prefer and may be leading to some of the confusion. We can deal more with that but first lets makes sure you can fix this first issue.
Are you familiar with blocks? If not we can help you figure out what that's all about so you better understand what may actually be going on here and how you can use it to your advantage in the future.
RogerRamjet
Post by RogerRamjet » Fri Jul 09, 2021 8:27 pm
Ryan,
You nailed it. I exploded the whole drawing (sounds bad, but worked good;)
Now I'm back to where I want to be.
I need to spend some time in the manual in order to be able to ask intelligent questions. But for now, your answer put me back in business.
Thanks a bunch
