Hi again,
When I open the Library Browser and open the default folder, then click on let's say, Architecture (or any of the others), there are no symbols to be found. I looked in the book for guidance, but it assumes there's content in the folders. What am I doing wrong? Or do I need to load a Library file?
Appreciate your help. Thanks.
Version: PRO 3.26.4.0 (3.26.4)
Windows 10
[solved] No symbols in my library
Re: No symbols in my library
did you update the DB?
- bambuko
- Senior Member
Glad somebody asked this question
because, lik OP I have the same problem...
It is supposed to be "Part library with over 4800 CAD parts"
but I can see barely few
and yes, I have updated.
QCad Pro
Linux MX-21.3 "Wildflower"
- petevick
- Premier Member
I don't think all the libraries are installed, but you can find them here -->> https://qcad.org/en/qcad-add-ons
Pete Vickerstaff
Re: [solved] No symbols in my library
Yes. Problem solved. Why is this not in the literature?
Thanks, Guys!
Thanks, Guys!
