inserted bitmaps, when switching between Linux and Windows SOLVED
Re: inserted bitmaps, when switching between Linux and Windows
Post by andrew » Mon Jul 05, 2021 1:30 pm
Could you please attach also the file as it is saved on your Windows installation? Thanks.
bambuko
Senior Member
Post by bambuko » Mon Jul 05, 2021 3:12 pm
...attach also the file as it is saved on your Windows...
Sure, this is the same folder as previously - the only thing I did was to open it and save in windows.
Qcad_test(saved_in_Win).zip
(830.4 KiB) Downloaded 318 times
QCad Pro
Linux MX-21.3 "Wildflower"
Post by andrew » Mon Jul 05, 2021 3:46 pm
bambuko
Senior Member
Post by bambuko » Mon Jul 05, 2021 4:00 pm
Thanks!
glad to see I wasn't going nuts :mrgreen:
QCad Pro
petevick
Post by petevick » Mon Jul 05, 2021 6:46 pm
petevick wrote:
Sun Jul 04, 2021 12:08 pm
might this be a problem with the path separator for Linux and Windows, ie, Linux uses / and Windows uses \
I might have been right then e_surprised e_surprised
Pete Vickerstaff
bambuko
Senior Member
Post by bambuko » Mon Jul 05, 2021 7:42 pm
...I might have been right then e_surprised e_surprised
Yeap e_ugeek sounds like it.
QCad Pro
bambuko
Senior Member
Post by bambuko » Tue Jul 06, 2021 7:03 pm
andrew wrote:...
I notice that the issue has been addressed:
https://github.com/qcad/qcad/commit/4f1 ... 6ebaecb523
Thank you!
I will change the status of this thread (to solved) as soon as I have a chance to test it :)
QCad Pro
bambuko
Senior Member
Re: inserted bitmaps, when switching between Linux and Windows SOLVED
Post by bambuko » Sun Sep 19, 2021 10:04 am
Solved wityh the latest (3.26.4.7) release - thank you.
QCad Pro
