[solved] How do I go to a specific X,Y?
DaleEltoft
Post by DaleEltoft » Tue Jun 29, 2021 2:38 am
How can I direct QCAD to scroll my view to a specific X,Y? For a large drawing zoomed in to work on details it would save me time scrolling about if I could just direct QCAD to go somewhere with a quick command.
8) It would be really handy if I could equate some names to specific points and then command QCAD to scroll to a point by name.
I'm using 3.64.4.0 on Windows
Re: How do I go to a specific X,Y?
Post by Husky » Tue Jun 29, 2021 3:09 am
I assume you are on QCAD Pro, correct?
What you are looking for is a widget which is called "View List".
Launch it, dock it where ever it suits your needs and use it to "jump" fast and directly to the saved views.
I think the widget is self explaining and I don't think that a Software guy like you needs more instruction on that. If I'm wrong I'm happy to help you with a setup. And yes - you can use your own name for each view ... :wink:
DaleEltoft
Post by DaleEltoft » Tue Jun 29, 2021 3:25 am
Yes I'm on Pro but obviously not a pro. Thanks that was exactly what I needed. :D
