How do I disble the debug logs produced by the CLI?
dyre
Post by dyre » Mon Jun 28, 2021 9:41 am
For the dwginfo cli-tool, running on ubuntu 16.04, I always get the following output in stdout
QCAD version  3.26.4
10:22:07: Debug:    Input file:  <PATH_TO_INPUT_FILE>
10:22:07: Debug:    calling odInitialize
10:22:07: Debug:    ...
How do I disable the debug logs and possibly the first line with the qcad version information?
Re: How do I disble the debug logs produced by the CLI?
Post by andrew » Mon Jun 28, 2021 9:47 am
You can redirect stderr to ignore debugging output. Use grep to skip the version.
Example:
./dwginfo .... 2>/dev/null | grep -v "QCAD Version"
Note that is is standard Posix and has nothing to do with QCAD command line tools.
dyre
Post by dyre » Mon Jun 28, 2021 10:01 am
I am running "dwginfo -l" to list all layers. So I'll cross my fingers that no layers is named "QCAD Version" for this grep filter:)
Post by andrew » Mon Jun 28, 2021 10:09 am
Feel free to use tail to simply skip the first line instead :)
