Defining and managing sections for large construction drawings
eronlloyd
Post by eronlloyd » Sun Jun 20, 2021 2:57 pm
Hi! I'm working on a construction drawing involving ~800 ft. of sidewalk, and there are key segments of the plan I need to produce detail sheets for. I know there are ways to define section markers and align them with the site plan, but I'm not clear on how best to proceed.
I believe AutoCAD automates some of this from what I'm reading, but I've never used that functionality and want to stick with QCAD. I have found plenty of section marker blocks, but how about the techniques to lay it out and produce plots properly? Any ideas?
Thanks!
Re: Defining and managing sections for large construction drawings
Post by CVH » Sun Jun 20, 2021 3:14 pm
Is this what you are looking for?
https://www.ribbonsoft.com/en/tutorial- ... -viewports
eronlloyd
Post by eronlloyd » Sun Jun 20, 2021 10:16 pm
Thanks CVH, viewports are definitely going to be useful, but I need to also better understand how to set up the overall plan view with a grid, then drill down with section detail views and maintain continuity.
Here's a video that does a good job of explaining the different aspects of such plans, but doesn't cover how to produce them. I'm sure QCAD can be used to create this, but I wish I could find a non-AutoCAD introduction to such technical drawing skills, even based on manual illustration, that covered such fundamentals.
Post by Husky » Mon Jun 21, 2021 7:59 am
Hallo ...
I would probably design the basic blocks for all common possible direction. A basic block could look like this one:
I named this block "Section marker VL". VL stands for Vertical Left.
Based on this block I designed 3 additional blocks (...VR, ...HD, ...HU) so that I can cover 4 directions.
Why not only 2 blocks and then flip them during the insertion? Because text in blocks will be mirrored when you flip them ... :(
https://www.qcad.org/bugtracker/index.p ... &closedto=
Here I covered two sections ...
Section marker blocks.gif (3.4 MiB) Viewed 2635 times
So much to your question: Any ideas? :wink:
