If I click on https://qcad.org/doc/qcad/latest/refere ... ngleLength , I can restrict angle, it works well but whatever I enter in the length box doesn't seem to affect the line I'm drawing. I can still draw line with any length....
PoP OS 20.10, Qcad 3.26.2
As you can see in the screenshot. I try to draw a line of 0.3 length but I can get a 97.2 length line... It doesn't limit it to 0.3 as expected.
[solved] How to restrict length of lines when drawing one
- resutl : length line = 97.2
- Capture d’écran du 2021-06-08 13-36-02.png (25.21 KiB) Viewed 2844 times
- drawing of line, desired to be of length 0.3
- Capture d’écran du 2021-06-08 13-35-23.png (57.03 KiB) Viewed 2844 times
Re: How to restrict length of lines when drawing one
That's great I didn't know. I didn't read this multiples of information before, good to know. It does indeed work.
Thank you andrew.
Thank you andrew.
