New CSV import tool
ryancousins
New CSV import tool
Post by ryancousins » Fri Jun 04, 2021 1:09 pm
The new CSV import looks very elegant based on the very helpful tutorial. https://qcad.org/tutorial-importing-poi ... s-from-csv
I wanted to try it out so I downloaded the example .csv file linked in the tutorial. When I tried to import it, I received errors for "unsupported text entries" for all of the text lines. Then it said "nothing casted" and that was it. I never saw the dialog box come up for this new tool. I'm sure I'm forgot to do something but at this point I'm not sure.
I'm running on Win10 Pro
Re: New CSV import tool
Post by andrew » Fri Jun 04, 2021 1:12 pm
I think you might be running CVH's CSV tool (Misc > Import/Export > Draw from CSV).
The new point / label import is under Misc > Import/Export > Import Points with Labels....
ryancousins
Post by ryancousins » Fri Jun 04, 2021 1:15 pm
Ahh, indeed. :oops: Thanks, Andrew.
