Scaling problem for DXF file generated in QGIS
Brianaurum
Post by Brianaurum » Sun May 30, 2021 3:56 am
When I open a DXF that I created in QGIS, the scale is around 1:100,000,000 and the x and y scale are not proportionate. My system is windows 10 64
My Qcad version is 3.26.2 professional and the QGIS version is 3.16.7 - Hannover. The CRS/GCS is GDA 94 and the scale for the exported file is 1. The created file opens and displays with correct proportions in QGIS. Does anyone have any suggestions? I have Thank you.
Brian
Re: Scaling problem for DXF file generated in QGIS
Post by andrew » Mon May 31, 2021 6:33 am
- Indicate the operating system you are using and the version thereof (e.g. Windows 10 32bit, Windows 8.1 64bit, Ubuntu 14.2 64bit, macOS 10.12, etc.)
- Indicate the exact version of QCAD you are using (see "Help" > "About" or "QCAD" > "About QCAD" or indicate the name of the file you have downloaded and installed)
- Attach original drawing files (DXF, DWG, ...) if appropriate
- Attach exported files (SVG, PNG, PDF, ...) if appropriate
- Include screenshots if appropriate
- If there is an error message, indicate the exact message or include a screenshot of the message
- If using a command line tool, indicate that exact command used
