[Solved] Options Toolbar checkboxes
ryancousins
Post by ryancousins » Thu May 20, 2021 1:31 pm
Is there a keystroke that will check a box in the options toolbar? I think the spacebar usually does that but outside of QCAD but that will bring focus to the CL in QCAD, so I didn't know if there was an alternative key to do it in here?
ryancousins
Re: Options Toolbar checkboxes
Post by ryancousins » Thu May 20, 2021 3:23 pm
I guess I just needed to mess around a little more with different key combos. Shift-Space will check a box in the options toolbar.
