[solved] Print multiple pages without overlap.
benjaminit
Post by benjaminit » Fri May 07, 2021 1:09 pm
I'm trying to print a drawing that has multiple pages of A3, each with a border in paper space and a viewport to model space.
when I print, I get a bit of the edge of the previous page on each page. I understand the overlap is there so you can stick the pages together to make a big page, but I want distinct pages. In Autocad I create a layout for each page but I can't seem to create additional layouts,
Thanks.
Re: Print multiple pages without overlap.
Post by andrew » Fri May 07, 2021 1:14 pm
Please refer to our tutorial "Working with Layout Blocks and Viewports" at:
https://qcad.org/en/tutorial-working-wi ... -viewports
benjaminit
Post by benjaminit » Fri May 07, 2021 1:24 pm
Thanks. Add Layout Block (BL) was what I should have spotted first.
