Export polyline vertices
Post by andrew » Thu Apr 22, 2021 7:58 pm
From a QCAD user:
How can I export polyline vertices into a text file, CSV or Excel?
Re: Export polyline vertices
Post by andrew » Thu Apr 22, 2021 8:06 pm
You can select the polyline(s) in question and use
Misc > Script Examples > Import / Export > Output Polyline Vertices
to output the vertices into the command line history as comma-separated values. This can then be copied / pasted into a CSV file for example.
This script could also be used as a starting point for a more sophisticated CSV export script:
https://github.com/qcad/qcad/blob/maste ... olyline.js
There's also a command line tool called dwg2csv which comes with every installation of QCAD Professional. This can be used to export polyline vertices to CSV as follows:
dwg2csv -f -t Polyline -p Type -p Vertex:X -p Vertex:Y pls.dxf
This produces a file polylines.csv with contents such as:
Type,Vertex:X,Vertex:Y
Polyline,,
Vertex,35,51
Vertex,47,65
Vertex,72,52
Vertex,69,36
Vertex,54,32
Polyline,,
Vertex,100.40549040452,42.175288556134
Vertex,106.5809484683,31.437620262786
Vertex,94.964349723221,26.002330941694
Vertex,92.299992212882,33.35595767023
