Automatically move to length box
- Newbie Member
When I first start QCAD when I select something like a Line Horizontal, if you start typing a number it goes directly to the length box. After using it for awhile it will not automatically go to the length box when typing a number. How do I get it "reset" to automatically go to the length input box after selecting a line type, circle, etc. Thank you in advance.
Re: Automatically move to length box
probably Ctrl+Space / ^Space
See: https://qcad.org/archives/shortcuts/shortcuts_en.pdf
That would be "Focus on Options Toolbar". Shortcut: Ctrl + space
- ryancousins
- Premier Member
I would add that, at least for me, the focus on the options toolbar persists each time you invoke a tool that accepts parameters in the options toolbar unless you change your focus to something else, such as the command line. Hitting the space bar will make the command line the active entry area, and as noted above by CVH and Husky, ctrl-space will bring it back to the options toolbar.
- focus.png (23.67 KiB) Viewed 3107 times
