[solved] How to move point of line or shape?
Markz
Post by Markz » Mon Apr 05, 2021 12:03 am
Is there a way to select a single end of a line, and then move it to an arbitrary location and have the line follow?
Likewise, can you move a single point in a polygon or other regular structure and have the other lines redraw automatically?
Thanks!
Panchdara
Re: How to move point of line or shape?
Post by Panchdara » Mon Apr 05, 2021 8:09 pm
There are 2 little things you should play with.
1) Left click and hold ON the point and then drag [that point]
2) Left click and hold on entity near a point and then drag.
2 distinct actions. Play with lines, polylines, circles, ellipses, blocks, dimensions.... play....
Play, play, play.....
Windows 10
Markz
Post by Markz » Mon Apr 05, 2021 9:12 pm
Dang. I thought I had tried that.
Thanks!
