There is align tool, but how can I distribute objects?
For exaple I have four objecs. How can I distribute them that the space horizontally between them will be the same but vertically will not change?
How can I distribute objects
Re: How can I distribute objects
There is currently no tool to distribute in QCAD.
- Registered Member
an alternative:
Draw a temp line and use the split tool to get some references with the same distance. After that use the align tool.
