[solved] How do I align my drawing with different paper?
turtle
Post by turtle » Thu Mar 25, 2021 7:03 pm
Hi all I am attempting to align this drawing at anew scale / paper.
Got the scale and paper changed.
entered print preview
then I try select all
cut with reference cntrl + shift + X
drawing disappears as expected
then
Cntrl + C to paste
click snap free
now nothing program seems frozen
am I missing something?
Posting a stripped down version of the file, the original has many more layers and 2 bitmaps, but this one still has the problem
Thanks for any advice!
--Turtle
copy_paste_problem.dxf
(262.28 KiB) Downloaded 328 times
Comments based on Version: 3.26.2 unless otherwise noted.
ryancousins
Re: How do I align my drawing with different paper?
Post by ryancousins » Thu Mar 25, 2021 7:17 pm
When I try your method it seems to work fine for me. I'm running QCAD 3.26.1 on Win10 Pro.
turtle
Post by turtle » Thu Mar 25, 2021 7:32 pm
Hmmm thats interesting thanks for trying so fast!
I am on 3.23 using Gentoo Linux.
So I started qcad from the cmd line so i could see errors and there are some new ones:
QCAD version  3.23.0
10:31:11: Debug:    checking for QCAD Pro updates...
Warning:  QSslSocket: cannot resolve CRYPTO_num_locks
Warning:  QSslSocket: cannot resolve CRYPTO_set_id_callback
Warning:  QSslSocket: cannot resolve CRYPTO_set_locking_callback
Warning:  QSslSocket: cannot resolve ERR_free_strings
Warning:  QSslSocket: cannot resolve EVP_CIPHER_CTX_cleanup
Warning:  QSslSocket: cannot resolve EVP_CIPHER_CTX_init
Warning:  QSslSocket: cannot resolve sk_new_null
Warning:  QSslSocket: cannot resolve sk_push
Warning:  QSslSocket: cannot resolve sk_free
Warning:  QSslSocket: cannot resolve sk_num
Warning:  QSslSocket: cannot resolve sk_pop_free
Warning:  QSslSocket: cannot resolve sk_value
Warning:  QSslSocket: cannot resolve SSL_library_init
Warning:  QSslSocket: cannot resolve SSL_load_error_strings
Warning:  QSslSocket: cannot resolve SSL_get_ex_new_index
Warning:  QSslSocket: cannot resolve SSLv2_client_method
Warning:  QSslSocket: cannot resolve SSLv3_client_method
Warning:  QSslSocket: cannot resolve SSLv23_client_method
Warning:  QSslSocket: cannot resolve SSLv2_server_method
Warning:  QSslSocket: cannot resolve SSLv3_server_method
Warning:  QSslSocket: cannot resolve SSLv23_server_method
Warning:  QSslSocket: cannot resolve X509_STORE_CTX_get_chain
Warning:  QSslSocket: cannot resolve OPENSSL_add_all_algorithms_noconf
Warning:  QSslSocket: cannot resolve OPENSSL_add_all_algorithms_conf
Warning:  QSslSocket: cannot resolve SSLeay
Warning:  QSslSocket: cannot resolve SSLeay_version
Warning:  QSslSocket: cannot call unresolved function CRYPTO_num_locks
Warning:  QSslSocket: cannot call unresolved function CRYPTO_set_id_callback
Warning:  QSslSocket: cannot call unresolved function CRYPTO_set_locking_callback
Warning:  QSslSocket: cannot call unresolved function SSL_library_init
Warning:  QSslSocket: cannot call unresolved function SSLv23_client_method
Warning:  QSslSocket: cannot call unresolved function sk_num
10:31:12: Debug:    Cannot download  "http://www.qcad.org/qcad/version/3_23_0_0_cohb5ophoox5xahc.html" :  "Error transferring http://www.qcad.org/qcad/version/3_23_0_0_cohb5ophoox5xahc.html - server replied: Not Found"
10:31:20: Debug:    calling odInitialize
11:14:51: Debug: dropped global XDATA (no res buf): "ViewportCenter"
Post by Husky » Thu Mar 25, 2021 7:45 pm
may I ask you a question?
So far so good but what is the goal for the next steps?
then
Cntrl + C to paste
click snap free
To change the scale - I don't think so.
To rotate the drawing - maybe ...
Please elaborate the goal of those steps. Thanks.
turtle
Post by turtle » Thu Mar 25, 2021 8:01 pm
Hi Husky, thanks
when I changed the scale the drawing no longer shows up in the same place.
I can post the original if you want.
Turtle
Post by Husky » Thu Mar 25, 2021 8:13 pm
You can move the Paper position in Print Preview. Would that solve the issue?
turtle
Post by turtle » Thu Mar 25, 2021 8:59 pm
Well golly that worked,
Thanks!
I knew it must be something simple I was missing.
I have always cut and pasted the entire drawing.
Still not sure why cut and paste did not work this time, perhaps drawing too big?
The hand fixes it, problem solved.
Thank you for Qcad!
