There is any way to close automatically the figure when i am going to draw the last line of my polyline? If the answer is yes, is there possibility to associate this command to a button?
[SOLVED] Close polyline automatically
- Polyline.png (11.48 KiB) Viewed 3178 times
Re: Close polyline automatically
Yes, on your Option ToolBar while constructing a Polyline: Regards,
Thank you!
I see ",C" in the text, it works for me to execute that by keyboard. In general, it is possible to change a key shortcut associated?
Many many thanks.
Regards.
Many many thanks.
Regards.
Very similar topic as:
viewtopic.php?f=89&t=8269
A easy button AND a functional shortcut. What does one want more?
OS related, yes, I can't on a windows 7.
No, these built-in shortcuts cannot be re-associated in direct.
That is perfect. Thank you. Regards.
